T113S4 LVGL UI 开发
本章节介绍在 T113-tina5v1.2-sdk 中快速完成 LVGL 示例应用开发闭环:新增示例代码 -> 交叉编译 -> 烧写系统 -> 启动后运行验证。
何时调用
  • 需要在 T113S4 上新增一个 LVGL 界面示例程序
  • 需要验证 LVGL 程序可在板端正常启动并显示
  • 需要联动 OpenixCLI 完成烧写与启动回归
默认约定
  • SDK 根目录:/home/ubuntu/T113-tina5v1.2-sdk
  • LVGL8 代码根:platform/thirdparty/gui/lvgl-8
  • 示例名:lv_hello_t113s4
  • 显示/输入后端:sunxifb + evdev
  • 镜像:out/t113_s4_linux_100ask_uart0.img
1. 新增示例源码
建议目录结构:
  • platform/thirdparty/gui/lvgl-8/lv_hello_t113s4/src/main.c
  • platform/thirdparty/gui/lvgl-8/lv_hello_t113s4/src/Makefile
  • openwrt/package/thirdparty/gui/lvgl-8/lv_hello_t113s4/Makefile
关键点:
  • main.c 使用 #include "lv_drivers/display/sunxifb.h"#include "lv_drivers/indev/evdev.h"
  • 初始化流程:lv_init() -> sunxifb_init() -> 注册 lv_disp_drv -> evdev_init() -> UI 创建 -> while(1){ lv_task_handler(); usleep(5000); }
  • custom_tick_get() 保持与 LVGL 配置一致
  • 字体优先使用当前配置已启用字体(如 lv_font_montserrat_16
2. 包构建接入(OpenWrt包)
openwrt/package/thirdparty/gui/lvgl-8/lv_hello_t113s4/Makefile 需包含:
  • include ../sunxifb.mk
  • Build/Prepare 拷贝源码、lvgl、lv_drivers、lv_conf.h、lv_drv_conf.h
  • Build/Compile 使用 TARGET_CC / TARGET_CFLAGS / TARGET_LDFLAGS
  • 安装到 /usr/bin/lv_hello_t113s4
3. 本地交叉编译快速验证
TMP=/tmp/lv_hello_t113s4_build
rm -rf "$TMP"
mkdir -p "$TMP/src"
cp platform/thirdparty/gui/lvgl-8/lv_hello_t113s4/src/main.c "$TMP/src/"
cp platform/thirdparty/gui/lvgl-8/lv_hello_t113s4/src/Makefile "$TMP/src/"
cp platform/thirdparty/gui/lvgl-8/lv_examples/src/lv_conf.h "$TMP/src/"
cp platform/thirdparty/gui/lvgl-8/lv_examples/src/lv_drv_conf.h "$TMP/src/"
cp -r platform/thirdparty/gui/lvgl-8/lvgl "$TMP/src/"
cp -r platform/thirdparty/gui/lvgl-8/lv_drivers "$TMP/src/"
make -C "$TMP/src" clean all \
CC=out/t113_s4/100ask/buildroot/buildroot/host/opt/ext-toolchain/bin/arm-linux-gnueabi-gcc
file "$TMP/src/lv_hello_t113s4"
期望输出:ELF 32-bit LSB executable, ARM
4. 烧写并启动验证
4.1 进入烧录模式
HOME=/tmp/adbhome adb shell 'reboot efex'
cd tools/OpenixCLI
sudo ./target/release/openixcli scan -l
期望看到 Mode: FEL
4.2 烧写镜像
sudo ./target/release/openixcli flash /home/ubuntu/T113-tina5v1.2-sdk/out/t113_s4_linux_100ask_uart0.img \
--reconnect-timeout-sec 240 \
--reconnect-interval-ms 300 \
-v
期望日志:All partitions flashed successfully
4.3 启动回归
HOME=/tmp/adbhome adb wait-for-device
HOME=/tmp/adbhome adb shell 'uname -a'
5. 板端运行示例验证
将示例推到板端并运行:
HOME=/tmp/adbhome adb push /tmp/lv_hello_t113s4_build/src/lv_hello_t113s4 /tmp/lv_hello_t113s4
HOME=/tmp/adbhome adb shell 'chmod +x /tmp/lv_hello_t113s4'
HOME=/tmp/adbhome adb shell '/tmp/lv_hello_t113s4 > /tmp/lv_hello_run.log 2>&1 & echo $!'
HOME=/tmp/adbhome adb shell 'ps | grep lv_hello_t113s4 | grep -v grep'
有进程即表示示例已启动。停止命令:
HOME=/tmp/adbhome adb shell 'killall lv_hello_t113s4'
常见问题
问题解决方案
openixcli scan -l 找不到设备adb shell reboot efex,或在 U-Boot 执行 efex
构建时报 lv_conf.h 缺失Build/Prepare 补拷贝 lv_conf.hlv_drv_conf.h
字体符号未定义改用配置里已启用字体(优先 lv_font_montserrat_16
buildroot 阶段出现 chown ... Invalid argument先用"本地交叉编译 + adb push运行"验证功能
